| cams https://slantsix.org/forum/viewtopic.php?t=7633 |
| Author: | andyman225 [ Sat Nov 22, 2003 4:05 pm ] |
| Post subject: | cams |
Has anyone used cliffords 260 cam. I'm currently using it in conjunctiowith thier maniflod and headers, but I'm a bit underwhelmed Oh by the way, the motor is in a 64 dart, Rebuilt PB auto w/ shift kit and V8 clutches, and 7.25 rear w/ 2.76 gears |
| Author: | Doctor Dodge [ Sat Nov 22, 2003 7:40 pm ] |
You really need to get away from that 2.76 gear, that is hurting you combo. Did you degree-in the Clifford cam? That should run pertty strong with 4 degrees of advance on it. Also check you distributor advance curve, a faster advance may help. DD |
| Author: | andyman225 [ Sat Nov 22, 2003 11:33 pm ] |
| Post subject: | advance |
I really want to put some 323 gears in it. I'm currently working on modifying a spare distributor I have laying around an see what happens. When I bought the cam I was afraid of going too radicle a cam with the stock stall converter. Now I'm wondering if I was too conservative? I didn't degree the cam |
