dist.
https://slantsix.org/forum/viewtopic.php?t=7636
Author:  dart4life [ Sat Nov 22, 2003 8:17 pm ]
Post subject:  dist.
What is recurving the dist.?
Author:  Doctor Dodge [ Sat Nov 22, 2003 10:12 pm ]
Post subject:  Re: Distributor Recurving
Distributor recurving is adjusting the mechinical advance to match the components / up-grades you have made to the engine.
For a SL6 this usually means adding initial advance and reducing the mechanical advance but getting it to come on faster.
Total advance without the vacuum advance should be around 30 to 32 degrees.
This article should help some:
http://www.dutra.org/doug/draft-webpage ... ibutor.htm
Author:  dart4life [ Sat Nov 22, 2003 10:29 pm ]
Ok where do i get this kit and is it worth all of the trouble?
thanks
