| cylinder head https://slantsix.org/forum/viewtopic.php?t=7643 |
| Author: | I_Lean [ Sun Nov 23, 2003 7:20 pm ] |
| Post subject: | cylinder head |
would it be a good idea to pickup another cylinder head and port it or is that something i should wait until after other modifications are done? |
| Author: | slantvaliant [ Mon Nov 24, 2003 6:20 am ] |
It would be a good idea to have a spare head to port, for a couple of reasons: 1. Your car isn't down while you do the work. You can take your time, then do the swap on a free weekend. 2. You can try to find a better head than your car came with. Doc has an article here about head selection. 3. Believe it or not, you might mess up the head - cut into a water passage, gouge a valve seat - and have to get that fixed. If you need the car and only have the one head, you're stuck. Hope this helps! |
