It is currently Fri Nov 27, 2026 1:00 pm
PostPosted: Thu Feb 26, 2004 12:18 pm
:roll: Sometimes I think my brain just keeps my skull in shape.
My 4 door Dart 270 has a noise coming from the rear at speeds 15 mph and over, yet I've checked everything back there only to get really dirty, sore hands and a pestering , nagging question only one of you gurus' could answer.
Due to the "elephant grunt" of torque coming out of these fascinating little 225's, can the transmission mount disintegrate internally? I had this happen on a racing poweglide (egad, did I say that here?) and it took me four driveshafts, not cheap and about 3 weeks to find.
Any ideas, oh those wise of the penta?!?
IS 40:31 gets me through lifes challenges.
PostPosted: Sat Mar 06, 2004 8:29 pm
how's your tires? certain tires can be noisier than others.Otherwise,refer to my "what noise?" theory.
PostPosted: Sat Mar 06, 2004 9:44 pm
My 1975 Valiant had a "noise" in the rear 7-1/4" axle around 20 MPH or more that i could not find. It got gradualy louder over the years. Made the same noise on asphalt, concrete, and gravel roads. Finally realize that the only thing that made it quieter was applying the brakes. That led me to the outer axle bearings, they were pitted like they had water in them. Installed new bearings and I could hear the radio again!
 Post subject: good points
PostPosted: Fri Mar 12, 2004 10:45 am
already looked at those and other issues, but, thanks for the input.
PostPosted: Fri Mar 12, 2004 2:57 pm
Pop the rear end cover off and see what the gears look like.
 Post subject: All Is Good Again!!!!!
PostPosted: Tue Mar 23, 2004 10:49 am
:lol: OKAY, SO THE PRIOR OWNER PUT A SET OF THOSE 4 FOR $99.00 TIRES ON THE CAR. THE TWO IN THE REAR WERE OUT OF ROUND.
TWO NEW TIRES WILL DO IT BUT SEE MY MAX TIRE THREAD
