| Has anyone bothered to insulate their roof? https://slantsix.org/forum/viewtopic.php?t=7803 |
| Author: | '74 Sport [ Mon Dec 08, 2003 7:02 am ] |
| Post subject: | Has anyone bothered to insulate their roof? |
Working on the interior now. Since I will have the headliner down to dye black, is their an insulation panel available to put underneath the roof, before the headliner goes back up. Seems like it would make the interior temperature more tolerable in this Texas summer sun. Any ideas? Jerry |
| Author: | mighty mouse 63 [ Mon Dec 08, 2003 10:25 am ] |
You could try a sheet of the foil backed insulating material, same as you would use on your floor boards, Get the kind that is not peel and stick as will have to cut it into indvidule panels to fit around the bracing use some contact cement or 3m spray adhesive, whichever you comfortable working with to secure the roof. Never, repeat never use the pink fiberglass insulation as it retains moisture. Hope this helps |
