It is currently Sat Nov 21, 2026 12:24 am
 Post subject: Rear Seat Removal
PostPosted: Sat Dec 13, 2003 6:42 pm
I can't seem to figure out how to get the bottom portion out and I don't want to break anything. Can somebody please tell me how to do this.
Signed,
Mopar Rookie :oops:
Future replica police unit: 1968 Plymouth Belvedere 4-Door (aka "Christine," according to my wife).
PostPosted: Sat Dec 13, 2003 6:55 pm
Contributor
With the seat flat against the floor, push the bottom of the seat towards the rear of the car and lift up.
PostPosted: Sat Dec 13, 2003 7:18 pm
Yup, there's a reinforcing rib on the inside of the seat at the bottom front, you just push on this until you feel the cushion release, then lift up while pushing and the ring will come out of the hook on the floor. You'll see what we mean when you get the seat out. Did you get the back out ok? Usually it's anchored on the bottom by bolts that are only accessible with the bottom cushion removed. Not sure about Darts Valiants etc. but usually there's a loop at either end at the bottom with a bolt through it, and the top is just hooked on to the speaker tray. You remove the two bolts at the bottom, then grip the seat back and slide it upward to remove it.
PostPosted: Sat Dec 13, 2003 7:41 pm
It also helps to have a scream fest during this operation. Cause if your back seat is like mine, you will. :shock: :wink:
PostPosted: Sun Dec 14, 2003 10:14 am
The scream rfest already came yesterday when I tried to remove it. :evil: I figured I'd break something if I continued so I decided to leave a post here for help :oops: I'll give the suggestions a try today. Thanks for the help.
PostPosted: Mon Dec 15, 2003 11:39 am
One of the mount hooks on one side of my seat was bent so just pushing on the fron of the seat didn't get it loose. Instead, I used a crowbar (straight end) and placed it between the two hooks so that the end was up against the bar that drops down from the frame through the hooks. While pushing rearward on the bar, lift the seat and it comes right out.
PostPosted: Thu Dec 18, 2003 10:11 am
I finally got it figured out. It was easier than I imagined. I guess knowing what direction to push and pull keeps the veins from popping out of your neck :shock: :D Thanks for the help!!!!
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
