It is currently Thu May 07, 2026 5:48 pm
PostPosted: Wed Aug 06, 2014 6:05 pm
when looking at the rear main seal / oil pan gasket instructions
http://www.slantsix.org/articles/gasket ... n-seal.htm
the photo of the rear main seal carrier is described as showing the carrier with the side that goes out board showing,, I agree with that, but it looks like the seal is in reversed, I am seeing the internal lip that should go in board,,anyone agree with that?
thanks
PostPosted: Thu Aug 07, 2014 12:12 pm
I can't tell from that pic's resolution whether the seal lip is in or out. But yes, the "lip" should face in. Also realize that for some seal manufacturers, the seal profile looks less like a "lip", & more like a wedge or lopsided triangle. For those the short side of the wedge is the inside of the "lip", & the long side is towards the outside (always check instructions from the gasket set to confirm!)
63 Valiant Wagon
225 - 4 bbl
Users browsing this forum: Evan lambert, Google [Bot] and 3 guests
