| Daily Driven 15 sec. car?? https://slantsix.org/forum/viewtopic.php?t=7865 |
| Author: | dart4life [ Wed Dec 17, 2003 5:07 pm ] |
| Post subject: | Daily Driven 15 sec. car?? |
Well I will be getting my Duster soon and was playing with the idea of a sl6.org car ,and want some advise,i want to know if it is smart to try to make this a 15 sec. car,for it will be my daily driver? I was thinking since i will be rebuilding the engine,bore the block 30 over,shave the head .1 with a felpro gasket,do some street porting like D.I suggested,stock valves,springs,and puhrods,comp 252s cam,prolinefuels dual webers,and dutra duals with dual 2 in. pipes all the way back through flowmasters.Also a 8 3/4 rear with 3.23 sure grip. and trying to decide what to do wih the tranny. What do you think am i thinking street rod or a fast reliable daily driver? open to all suggestions thanks |
| Author: | greasy 225 [ Thu Dec 18, 2003 12:32 am ] |
I've been wondering the same thing, reliable 15sec. \6. What all would be involved, I would actually like to put a turbo on mine aswell but I'll never get around to that. -Jesse |
| Author: | Dart270 [ Thu Dec 18, 2003 7:29 am ] |
There are several of these running around. Check out http://www.slantsix.com/UBB/Forum4/HTML/000051.html Lou |
| Author: | Guest [ Thu Dec 18, 2003 4:10 pm ] |
Hey Lou with the dual dutra duals did you have to go with a mini starter? if so how do you like it? thanks for the artical,it gets me thinking! Jared |
| Author: | Dart270 [ Thu Dec 18, 2003 7:14 pm ] |
I already had a mini starter in the car, so yes. I doubt I will ever use a stock Mopar starter again. They were a great design for 40 years ago, but the minis are lower power and weight. Lou |
| Author: | slantzilla [ Thu Dec 18, 2003 7:59 pm ] |
I drove my Duster all over when it was running 15's. I also drove my '66 all over when it was running 14's. |
| Author: | 70valiant [ Sun Dec 21, 2003 10:57 am ] |
jared, to run 15flat you need to make 210hp for a 3100lb car. whith what you are talking about building you should be very clost to that. I expect to run right around 16sec 1/4's with my setup, and I havent touched the cam or the rear. |
