It is currently Fri May 01, 2026 9:43 am
PostPosted: Wed Jan 14, 2004 8:26 pm
The partsamerica web site lists a replacement rotor for 1966 a-body discs Bendix 141054
There is no other info listed -
Has anyone used this part on their car?
Is this a small bolt pattern (5 lug 4" circle) rotor?
Any one has more detail info for Bendix parts?
Thanks for your help.
PostPosted: Wed Jan 14, 2004 10:52 pm
That is the rotor designed to go with the kelsey hays 4 piston 5 on 4" brake setup. Any pre 73 disc brake setup on A bodies were 5 on 4". Remember these rotors are two piece, seperate hub, and no the seperate hub is not included with the rotor.
I have two of those bendix rotors on my 71 duster w/sbp discs. I got them from the local monument auto parts, I don't recall exactly how much they were but I believe they were $150 for a pair. I doubt you can get the hubs from a parts store any more. Junkyards are your only choice on that one.
