Stray Wire Near Volt Limiter
https://slantsix.org/forum/viewtopic.php?t=8099
Page 1 of 1
Author:  67 LAWNDART [ Wed Jan 14, 2004 11:13 am ]
Post subject:  Stray Wire Near Volt Limiter
:? OKAY, HERE WE GO.
I JUST DISLODGED MYSELF FROM UNDER THE DASH OF MY 67 DART. I WAS INSTALLING A VOLTAGE LIMITER WHEN I FOUND AN UN-ATTACHED WIRE REAL CLOSE TO IT WITH A "BLADE" TYPE CONNECTOR. WITH THE INSTRUMENT CLUSTER STILL INSTALLED, IT IS TOUGH TO SEE UP IN THERE, SO I DONT KNOW WHAT ITS FOR OR WHAT COLOR IT IS.
ANY THOUGHTS? THE WIRING DIAGRAM IN MY HAYNES BOOK DOESNT SHOW IT, BUT, IT HAS ONLY 3 INCHES IN LENGTH OUTSIDE THE MAIN HARNESS. THAT INDICATES FACTORY TO ME AS THE HARNESS IS NOT MODIFIED. :idea: MAYBE THE DASH PANEL TO ENGINE GROUND?
Author:  steponmebbbboom [ Thu Jan 15, 2004 6:23 pm ]
It could be a pigtail for an optional accessory that wasnt installed in your car.
Author:  GuyLR [ Sat Jan 17, 2004 9:38 am ]
If the wire is black it is probably a ground as you suspect. Some of the voltage limiters have a blade that sticks up off the cover for a ground wire to connect. That's my best guess of what you have.
