It is currently Sun Oct 25, 2026 8:55 pm
PostPosted: Mon Oct 28, 2002 4:03 pm
Hello. I have a 67 A100 with a 225 /6. I removed
the stock rope seal and installed a rubber one
twice now per Dougs instructions. The rear seal
still leaks. I'm convinced it is because my crank
has factory nerrling to help keep the the rope
seal lubed. The nerrling is very deeply machined.
I would like to install a rope seal without dropping the crank. Has anyone used a sneaky pete
on a /6 with success??
Thanks
Mike in WA
huskynox@yahoo.com
PostPosted: Mon Oct 28, 2002 8:16 pm
: Hello. I have a 67 A100 with a 225 /6. I
: removed
: the stock rope seal and installed a rubber one
: twice now per Dougs instructions. The rear seal
: still leaks. I'm convinced it is because my
: crank
: has factory nerrling to help keep the the rope
: seal lubed. The nerrling is very deeply
: machined.
: I would like to install a rope seal without
: dropping the crank. Has anyone used a sneaky
: pete
: on a /6 with success??
: Thanks
: Mike in WA
I've never had a problem with the neoprene seal. Only two things I can think of:
The lip seal is facing the wrong direction(most likely), or, and this is a long shot, it is a marine crankshaft made to rotate opposite direction, so knurling is in the wrong direction.
fglmopar@aol.com
PostPosted: Mon Oct 28, 2002 8:58 pm
: I've never had a problem with the neoprene
: seal. Only two things I can think of: The
: lip seal is facing the wrong direction(most
: likely), or, and this is a long shot, it is
: a marine crankshaft made to rotate opposite
: direction, so knurling is in the wrong
: direction.
Sneaky Pete works but man...what a nasty job.
You should break loose oll the mains and let the crank "hang down" as much as possible before you slip-in the new rope seal.
I would take the time needed to inspect and measure things, something is not right and changing rear main seals is a real pain. I'm not convinced that the heavy knurl would cause a big leak.
