It is currently Sun May 10, 2026 12:38 pm
PostPosted: Fri Dec 30, 2005 9:07 pm
I was just wondering, how many different /6 passenger car oil pans are there, and what's interchangable? I remember reading that the '63-66 A-cars use a different pan & pick-up than the '67-76 cars. How many different pans are there among the A, B/E, C, F/J/M and R bodies?
I know this has prolly been addressed before, but searching "oil pan" brings up a gazillion (well, 623) posts.
Thanks!
Brian (Valianator)
'65 Valiant V100 170/T-flite
'82 D150 225/4-speed
'65 Dart 225 4 door
'68 Dart 225 4-door with Valiant front clip (future project)
 Post subject: Oil pan
PostPosted: Sun Jan 01, 2006 1:30 pm
The big difference which I have experienced.
those 67-76 a bodies have the deep part of the pan farther to the front than the F/J/M bodies due to the changes to the torsion bar suspension. The 67-76 dart style pan will NOT fit into and F/J/M body.(I've tried) But, that means that the F/J/M pan can fit most earlier car applications since the low spot starts farther back than any model I have seen. I believe it is important to keep the pan matched to the pickup tube, so keep them as a set.
It also appears that the earlier 63-66 motors where positioned farther forward than the later 'A' body motors. That means that the early pans are very likely to fit the later 'A' bodies, but I don't know if they will fit the F/J/M bodies.
I don't expect that the 63-66 pan would fit F/J/M. Also, 'A' bodies did not cross exhaust under the oil pan, so the only clearance issue is in the front, While a factory 'F' body crosses under the pan and requires another aspect of clearance. Best to stick with their own kind on the F/J/M models.
I never owned or worked on B/E cars, so I can't help there.
Truck pans are too deep for any of the cars as a general rule and car pans won't work on trucks due to even greater clearance requirements up front.
1980 Aspen 225 super six
PostPosted: Sun Jan 01, 2006 5:44 pm
I attempted to put a 74 oil pan in my 61 Valiant (with a 65 kmember
and suspension) The rear of the 74 pan sits on the center link.
A 63 pan has about 3/4 of an inch clearance.
In this thread Doctor Dodge posted a picture with 6 oil pans.
http://www.slantsix.org/forum/viewtopic ... +pic#51749
PostPosted: Mon Jan 02, 2006 11:12 am
The F/M/J pans can be made to work in an early A-body by using the V8 center link and denting the right front corner of the sump.
PostPosted: Mon Jan 02, 2006 11:58 am
I used an F-body oil pan in a 66 Cuda (v-8 center link) and didn't need to dent anything.
PostPosted: Tue Jan 03, 2006 7:05 pm
Thanks, fellas.
Looks like the best bet is to just transfer the original pan & pick-up from my 170 if I go for a 225 swap later. 8)
Brian (Valianator)
'65 Dart 225 4 door
Users browsing this forum: Amazon [Bot] and 2 guests
