| Need Clutch Advise https://slantsix.org/forum/viewtopic.php?t=8112 |
| Author: | SBNEWC33 [ Thu Jan 15, 2004 7:38 am ] |
| Post subject: | Need Clutch Advise |
It's time to start my 3-on-tree to OD-833 swap and I'm also in dire need of a new clutch assy. I've read the clutch article on this web sit but I'm still scratching my head some. So for a 73' Dart /6 with OD-833, 8.25 open rear of 3.21 ratio, and stock to slightly warmed motor, what would be a good clutch choice. I need to keep cost down and I plan no smokey burnouts, only spirited driving on occasion, so please advise, thanks. |
| Author: | damxwiz [ Thu Jan 15, 2004 9:03 am ] |
| Post subject: | clutch conglomeration |
You need to make sure your flywheel/bellhousing will accept it but I have a d-100 truck with 131" wheelbase, 3.23 gears(open), and 833od, with the 10 inch clutch and it will fry the tires (235/70/15). |
| Author: | junkyardhero [ Thu Jan 15, 2004 10:33 am ] |
your choice will be based on what size bellhousing/flywheel combo you have. If you're running a 10.5" setup you're golden. I've had great luck with sachs pressureplate/disk combos and hayes makes high quality units. Centerforce is cool beans too, if you're looking to drop that kinda coin. Good luck! -JYH |
| Author: | Old Car Scott [ Fri Jan 16, 2004 10:23 am ] |
Quote: Centerforce is cool beans too, if you're looking to drop that kinda coin.
I have a CenterForce Dual Friction in my '68 Charger with a very very strong 440, and I've never had a better pressure plate/clutch!
Good luck! -JYH |
| Author: | SBNEWC33 [ Fri Jan 16, 2004 11:15 am ] |
| Post subject: | Clutch Advise |
I'll be using the stock /6 flywheel, so my take from the clutch assy article is that the 10 inch B & B "cover type" 3 lever unit is about the best I can do, but please correct me if I'm wrong. Thanks for the responses |
| Author: | Doc [ Fri Jan 16, 2004 12:05 pm ] |
Yes, the 10 inch "HD" Truck / Taxi SL6 clutch should work fine for what you have. Be sure to check for cracks in the cover, righ around the cover mounting bolts. DD |
| Author: | SBNEWC33 [ Fri Jan 16, 2004 1:01 pm ] |
| Post subject: | Clutch Advice |
Thanks Doc |
