| Engine Id https://slantsix.org/forum/viewtopic.php?t=8126 |
| Author: | mszauner [ Fri Jan 16, 2004 8:44 am ] |
| Post subject: | Engine Id |
OK, I am back home again. I am almost positive I have hydraulic lifters but will buy a tool this weekend and remove for examination. I am really suspecting that the engine block is newer than earlier believed. My problem is that I have searched several websites and cannot seem to find anything that matches the coding on my engine. The ID boss (rear passenger side of engine just below head) says: R13 762 The stamping on the front passenger side (below alternator) says: 1 225R 11 5 E Under the manifold are two castings: 330-1 and 0850 with AAWJ just below it. Can anyone please tell me what year engine I have based upon these numbers? Thank you very much, once I know the year for sure, I can get this problem solved. Mike |
| Author: | 60Pioneer [ Fri Jan 16, 2004 9:37 am ] |
From what you describe, you probably have the last generation forged crank motor. These have been described here as "30" blocks. I bought one out of a 76 Dart Lite. Nothing wrong with these blocks. I believe you'll find solid lifters. Limit your boring activities to 060" or less and you'll be in fine shape. |
| Author: | kesteb [ Fri Jan 16, 2004 4:12 pm ] |
I suspect it is a '81 block. The 11 in the stamping is a date code from 1970. Pre 1970 is a letter code. |
| Author: | volaredon [ Sat Jan 17, 2004 12:51 pm ] |
The E after the 225 in the one spot denotes a cast crank. |
| Author: | steponmebbbboom [ Sat Jan 17, 2004 6:17 pm ] |
Quote: The E after the 225 in the one spot denotes a cast crank.
So you mean the "E" at the end, or an "E" where there is an "R" right now?1 225R 11 5 E |
