Slant Six Forum https://slantsix.org/forum/ |
removing cat from '72 https://slantsix.org/forum/viewtopic.php?t=8290 |
Page 1 of 2 |
Author: | milesius [ Mon Feb 02, 2004 2:53 pm ] |
Post subject: | removing cat from '72 |
It doesn't need it. is there an easy home-brew way of removing the cat converter from my 72 swinger? |
Author: | Pierre [ Mon Feb 02, 2004 2:58 pm ] |
Post subject: | |
Get a hacksaw or sawzall, chop off both ends, then link the rest of the pipe together with flexible exhaust pipe replacment by clamping it on both ends. This stuff should be availible at your local auto store. Or you can reach in with a long screwdriver and push all the stuffing loose, and it will eventually blow out the tailpipe. Depending on your mufler design this could clog it though. |
Author: | GTS225 [ Mon Feb 02, 2004 4:22 pm ] |
Post subject: | |
A catalytic convertor!?.....on a '72?! ![]() Roger |
Author: | Pierre [ Mon Feb 02, 2004 5:07 pm ] |
Post subject: | |
Roger, thats what my thoughts were. I know cats started in 73.. maybe this is a later 72 model that was made close to the cutoff? |
Author: | Slanted73 [ Mon Feb 02, 2004 6:03 pm ] |
Post subject: | huh? |
You mean my 73 is supposed to have one? ![]() |
Author: | SlantSixDan [ Mon Feb 02, 2004 6:08 pm ] |
Post subject: | Holy cats! |
Catalytic converters did not appear on Slant-6 cars until 1975, and then only on some of them. In the USA, the first year during which all Slant-6 cars had catalysts was 1977. In Canada, it was 1980. So no, a 1972 or 1973 is NOT supposed to have one. |
Author: | steponmebbbboom [ Mon Feb 02, 2004 6:18 pm ] |
Post subject: | Re: Holy cats! |
Quote: Catalytic converters did not appear on Slant-6 cars until 1975, and then only on some of them. In the USA, the first year during which all Slant-6 cars had catalysts was 1977. In Canada, it was 1980.
WOOHOOO Canada! So no, a 1972 or 1973 is NOT supposed to have one. ![]() |
Author: | Pierre [ Mon Feb 02, 2004 10:08 pm ] |
Post subject: | |
I'm pretty sure that I've seen earlier then 77 cars in the wreckin yard with cats in them. |
Author: | DusterIdiot [ Mon Feb 02, 2004 10:17 pm ] |
Post subject: | 1975-1976 Not Standard.... |
1975 models were the 'beginning' of the end with the introduction of the Monolith Cat convertor in many models. I've never seen one in a pre-75 unless someone either transplanted 1975 + pipe or had to do it for 'emissions reason's '....(like those 'third brake lights' in the rear window). You'll find a fair number of F-bodies with them, and most A-bodies from 1975-1976 have them, there is 'sometimes' a silver sticker with black lettering (colors did change) attached to the driver's door above the latch that would say something like 'Catalytic Convertor Equipped' or 'Non- Catalyst Equipped Car'....Some cars in other brands made it all the way up to 1978 with no cats...(A buddy had a Numbers Matching SD455 4 speed Firebird with no cats, and the nice 'no cats' sticker). I'm sure destination state or 'export' cars had something to do with who got cats or not, along with powerplant and drivetrain options.... -D.Idiot |
Author: | Craig [ Mon Feb 02, 2004 10:24 pm ] |
Post subject: | |
Quote: ..... then link the rest of the pipe together with flexible exhaust pipe replacment by clamping it on both ends......
No no no, you need a rigid piece in there so the rest of the pipe stays up in place. A Flexible piece will let it sag and drag on the road.
Author: | Pierre [ Mon Feb 02, 2004 10:28 pm ] |
Post subject: | |
The flexible pipe I've seen isnt that flexible Craig. If you want a solid pipe there you can always take the car to the muffler shop and give em $20 bucks to weld on a length of pipe. |
Author: | SlantSixDan [ Tue Feb 03, 2004 8:03 am ] |
Post subject: | |
Quote: I'm pretty sure that I've seen earlier then 77 cars in the wreckin yard with cats in them.
Check what I wrote: *SOME* Slant-6 cars got them starting in '75, *ALL* Slant-6 cars in the US got them starting in '77.No cars got them before '75, and there have never been any emission laws in any state or Canadian province that would require the installation of a converter on a car not originally so equipped. |
Author: | GTS225 [ Tue Feb 03, 2004 8:10 am ] |
Post subject: | |
This got me to thinking, (dangerous, I know ![]() Maybe a west coast guy can enlighten the rest of us. Roger |
Author: | Pierre [ Tue Feb 03, 2004 11:55 am ] |
Post subject: | |
Well, let me rephrase my statment, I'm pretty sure I've seen pre-75 cars with cats. Roger, in California any car older then 30 years is exempt from the smog program entirely. That's why pre-74 cars are hot now and those are the first to go. |
Author: | Marc [ Tue Feb 03, 2004 12:47 pm ] |
Post subject: | |
I live in CA and have a 65 and a 68 B'cuda. Neither has a cat and they never needed one when they had to be smogged. |
Page 1 of 2 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
