adjust the low/reverse band
https://slantsix.org/forum/viewtopic.php?t=8402
Page 1 of 1
Author:  milesius [ Fri Feb 13, 2004 11:11 am ]
Post subject:  adjust the low/reverse band
How do you adjust the low/reverse band? I am going to be pulling my /6 soon and my tranny was having trouble shifting when it was cold, otherwise it is new.
Author:  Slant Cecil [ Fri Feb 13, 2004 1:07 pm ]
While the second gear/kickdown band adjustment is external, the manual low/reverse band adjustment is inside the pan.
If your trans shifting problem is when the trans selector is in Drive, the manual low/reverse band adjust has no affect. This band is only applied when the trans selector is in Reverse or 1 (Low).
Cecil
Author:  milesius [ Fri Feb 13, 2004 4:13 pm ]
Post subject:  cool , thanks for explaining
Ok, so if my tranny doesnt shift while in drive, because it is cold, it must be related to something else.
