It is currently Thu Feb 20, 2025 12:00 pm
PostPosted: Sun Feb 15, 2004 6:59 pm
The Slant racing manual said - "The best production cam available for
the slant six engines was used in the 1971-1977 engines. This cam
(PN 3512639) has a 244 degree duration, 26 degree overlap and
a lift of .406" on the intake and .414" on the exhaust. "
It does not tell at what degree of timing the intake opens - Has anybody
measured the valve events on the stock Cam ?
I would like to compare the "effective compression ratio" of the stock
cam and a couple that are canidates for a 170 build. This is to help
determine what static compression ratio to shoot for.
PostPosted: Sun Feb 15, 2004 9:43 pm
Here are the events (in degrees) taken @ .050" lift:
Intake opens @ 8 ATC, closes @ 26 ABC, duration = 198
Exhaust opens @ 33 BBC, closes @ 10 BTC, duration = 203
Users browsing this forum: Ahrefs [Bot] and 11 guests
