It is currently Fri Nov 27, 2026 11:39 am
PostPosted: Sun Nov 30, 2003 9:47 am
The torque converter on my Dart was replaced not too long ago before I bought it and I am a little doubtful about whether it's correct. The ring gear tooth count is only 122 and it has the large pilot (1-3/4 I think). I say this because the ring gear teeth are already showing wear on the front face. The starter looks original. Shouldn't I have 123 teeth?
I counted twice.
PostPosted: Mon Dec 01, 2003 6:46 am
If you bought a TC for a Slant or a SB v8, then I don't see how it could be wrong. I believe the stock count is 122, but I'm not 100% sure. The wear could be from a faulty starter drive. Some wear is normal.
PostPosted: Mon Mar 22, 2004 12:02 pm
while I have the tranny out, i want to upgrade to a reduction drive starter, [preferrable the newer mini style from say a 1990 dakota V6]
My original style direct drive starter has 9 teeth and the ring gear has 148 teeth.
I believe the stock chrysler reduction starter has 10 teeth and the corresponding ring gear on the torque converter has 122 [or 123] teeth on the ring gear [according to the comments in this thread] and up until 68, had the small nose I need for my pushbutton tranny.
My questions are these:
Q1 How many teeth does the later style converter for the reduction drive starter have?
Q2 In which year was the reduction starter drive introduced?
Q3 In the end, which year of stock converter would work for a reduction drive starter and have the small dia nose? . . . 64 - 66 tranny/engine??
Cheers!
Al T
PostPosted: Mon Mar 22, 2004 3:23 pm
corrected tooth count errors
Cheers!
Al T
PostPosted: Mon Mar 22, 2004 8:32 pm
There are 122 teeth on the convertor my 63 dart
uses with the reduction gear type starter.
1962 (According to Chilton's)
And consistent with my 61 valiant having a direct drive starter
and the 63 dart having a reduction gear type.
So 63 to 66 would have the reduction gear starter compatible ring
gear and the small nose converter.
 Post subject: thanks Relic lover
PostPosted: Mon Mar 22, 2004 9:00 pm
really appreciate the timely info. Thks
Cheers!
Al T
