| Differential Leaking https://slantsix.org/forum/viewtopic.php?t=8542 |
| Author: | nn200404 [ Fri Feb 27, 2004 8:28 am ] |
| Post subject: | Differential Leaking |
I have a 73 Duster with a /6 and Auto 3 spd, and the differential leaks excesively. Is this normal? nn2004@peoplepc.com |
| Author: | Doc [ Fri Feb 27, 2004 8:45 am ] |
| Post subject: | Re: Differential Leaking |
Quote: I have a 73 Duster with a /6 and Auto 3 spd, and the differential leaks excesively. Is this normal?
No, the rear end should not leak a single drop of oil.nn2004@peoplepc.com You most likely have a bad pinion seal or a leaking cover gasket. Clean the unit, refill and check it closely to see where the leak is coming from, then replace that seal / gasket. DD |
| Author: | Pierre [ Fri Feb 27, 2004 3:21 pm ] |
This may only be applicable to the 8 3/4" rear, but I'm sure someone will chime in if that is the case On the driver side of the axle, there is a "T" fitting on the end of the rubber brake hose. The screw holding the fitting to the rear end is actually a vent, and if this vent screw is clogged then excessive pressure can build up in the rear end and cause a leak. |
