It is currently Sat Nov 28, 2026 5:41 am
 Post subject: Welded Spiders
PostPosted: Sat Mar 06, 2004 12:50 pm
Someone please help me understand this. I seen some gears for sale that said welded spiders? Then in the last issue on the SSRN (Thanks Seymour) I noticed that Gary Bruner's running welded gears. My question is, does this just turn the center into a "spool"? I have a 3.91 open rear that has a little gear noise that isn't good for anything else, and I may try this for a set-up in my race-car. I know it could'nt be used on the street.
Any "strength" issue with this set -up? Anyone got a picture of where they welded?
Rick
PostPosted: Sat Mar 06, 2004 8:09 pm
Yes, welded spider gears work just like a spool , a full time "locked" rearend.
Weld the gears everywhere you can, where the gears meet-up with the carrier and where the teeth intersect.
As for durability, the 7 1/4 carrier is small and it will not take a bunch of load. I have split a 7 1/4 carrier in half, with-out welded spider gears. :shock:
PostPosted: Sun Mar 07, 2004 5:06 am
FWIW: No racing association allows welded spiders in competition. So if your racing, it would depend on the tracks tech inspection.
