Slant Six Forum https://slantsix.org/forum/ |
radiator problems https://slantsix.org/forum/viewtopic.php?t=8682 |
Author: | gwp36530 [ Wed Mar 10, 2004 6:09 pm ] |
Post subject: | radiator problems |
today smoke started comming out of the hood when i got back to the house. when i opened the hood, hot antifreeze was all over the engine bay (this is the second time this has happened). i have noticed that alittle too much fluid has been comming out of that drain hose on the radiator. i have used 13 and 15 lb. caps and the same thing happens. anyone know what my problem is? thanks -robert- |
Author: | steponmebbbboom [ Wed Mar 10, 2004 7:41 pm ] |
Post subject: | |
Your engine is either overheating, probably due to a bad thermostat, or you have a combustion leak (bad head gasket). Process of elimination. |
Author: | Michael_Cuda [ Wed Mar 10, 2004 11:55 pm ] |
Post subject: | |
if you have a blow head gasket often there will be a film of oil in your coolant, same look oil gets when on wet pavment. |
Author: | mighty mouse 63 [ Thu Mar 11, 2004 10:40 am ] |
Post subject: | |
Have you checked that pesky by-pass hose? had one develope a split, drove me crazy for a week as it would not revel itself with the hood open. |
Author: | Michael_Cuda [ Thu Mar 11, 2004 11:46 am ] |
Post subject: | |
I have had 2-/6 by-pass hoses spilt on me. Both were very clear, was it a small spilt? |
Author: | rambo13300 [ Mon Mar 15, 2004 5:51 pm ] |
Post subject: | rad problems |
my 76 volare with 53000 miles started runing warmer than normal but i did'nt let it get over heated and since i had done been thru this before with my 78 dip i knew what to do this time,i ordered a new radiator online and 3 days later new rad on and problem solved. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
