Slant Six Forum https://slantsix.org/forum/ |
vacuum advance https://slantsix.org/forum/viewtopic.php?t=8704 |
Author: | ruru 2 [ Sat Mar 13, 2004 4:29 pm ] |
Post subject: | vacuum advance |
Does a 225 slant six have full or timed vacuum advance? And also what does the timing need to be set at at? |
Author: | 63gtcv [ Sat Mar 13, 2004 6:32 pm ] |
Post subject: | advance |
The vac. advance works as stated. The 'pull' of yhe carb. vacuum is what moves the spark timing forward. The other advance system is mechanical. Both have limits witch can be adjusted. |
Author: | Doctor Dodge [ Sat Mar 13, 2004 8:32 pm ] |
Post subject: | |
What year is the Vehicle? Is it stock or have there been any improvements made? You may want to read thru this article about distributor recurving. http://www.dutra.org/doug/draft-webpage ... ibutor.htm DD |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
