Slant Six Forum https://slantsix.org/forum/ |
Oil Pressure https://slantsix.org/forum/viewtopic.php?t=8711 |
Author: | 73dart_swinger [ Sun Mar 14, 2004 12:35 pm ] |
Post subject: | Oil Pressure |
My all stock, all original slant six runs about 30-32 psi of oil pressure most of the time. Every once in a while i start it up and it'll run about 40 psi. Anyone got an idea why it does this? What kind of oil pressure is anyone elses engine running? I really don't know how many miles are on the engine but i'm guessing it's somewhere around 115,000. |
Author: | Eric F [ Sun Mar 14, 2004 2:53 pm ] |
Post subject: | psi |
your oil pressure should be a little higher when the oil is cold |
Author: | johnnysix [ Sun Mar 14, 2004 9:55 pm ] |
Post subject: | |
Eric F took the words right out of my mouth !! I only wish i could afford an oil pressure gauge for my sweet slants !!! |
Author: | Charrlie_S [ Mon Mar 15, 2004 5:32 am ] |
Post subject: | |
Gauge should only cost about $10. If you want to keep the light, and have the gauge also, add about $3 for a "T" fitting. |
Author: | slantvaliant [ Mon Mar 15, 2004 6:04 am ] |
Post subject: | |
Upgrading to copper line (over the plastic line usually supplied) is a good idea, too. Leave a nice loop in the system to allow for some flex. I also painted the mounting bracket for my below-the-dash gauge. The red I used doesn't quite match the dash, but it's close enough for now. |
Author: | Doc [ Mon Mar 15, 2004 8:59 am ] |
Post subject: | Re: Oil Pressure |
Quote: My all stock, all original slant six runs about 30-32 psi of oil pressure most of the time. Every once in a while I start it up and it'll run about 40 psi. Anyone got an idea why it does this? What kind of oil pressure is anyone elses engine running?
Cold / thick oil will put more pressure on the gauge.Most of my Slants run 30-35 psi at hot idle and 50-55 psi at anything over 2500 RPM or so, except for the HV pump I have in my wagon engine, that one runs 52 psi all the time, even at hot idle. You may want to increase the relief valve spring pressure, that will increase the hight rpm running pressure. (external plug on the oil pump gets you to the spring, stretch or shim it up) DD |
Author: | 73dart_swinger [ Mon Mar 15, 2004 1:20 pm ] |
The oil temperature doesn't seem to have anything to do with it. It usually starts up cold at 32 psi. The next time i start it and its warm it might be 42 psi. And it might be the other way around too. It just sporadically starts and has different oil pressures. |
Author: | slantvaliant [ Mon Mar 15, 2004 1:33 pm ] |
Post subject: | |
Maybe a flaky gauge? |
Author: | Doc [ Mon Mar 15, 2004 1:42 pm ] |
Post subject: | |
A dirty or defective by-pass oil filter can also cause that. DD |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
