| Wheel Adapters https://slantsix.org/forum/viewtopic.php?t=8775 |
| Author: | 73dart_swinger [ Sun Mar 21, 2004 9:46 am ] |
| Post subject: | Wheel Adapters |
What do you guys think about the adapters that change your bolt pattern from 4" to 4.5"? How safe are these? How much will they affect my backspacing if i switch over to the large bolt pattern? Can i take up the slack with a spacer or something? Does anyone have experience with these? |
| Author: | (74.swinger) [ Sun Mar 21, 2004 11:49 am ] |
dont use them they are no good. They break |
| Author: | slantzilla [ Sun Mar 21, 2004 1:06 pm ] |
I've got a set out in the garage that were on the front of a low-11 second big block Demon for over 10 years. They never broke. Check the lug nuts occasionally (both spacer and wheel) and don't drive like a dummy and you'll be OK. Yes, they will affect wheel spacing by about 3/4". |
| Author: | 73dart_swinger [ Sun Mar 21, 2004 2:24 pm ] |
| Post subject: | Adapters |
it sounds like your car was mainly for straight lines. What if the road gets a little twisty and i wanna go fast? Would i have to worry about something breaking then? Does that qualify as driving like a dummy with wheel adapters? |
| Author: | Eric W [ Sun Mar 21, 2004 5:44 pm ] |
If your going to drive the snot out of your car, personally, I wouldn't trust them. If you want big bolt pattern, convert. |
