| column interchange ? https://slantsix.org/forum/viewtopic.php?t=8916 |
| Author: | hornet [ Sun Apr 04, 2004 8:06 am ] |
| Post subject: | column interchange ? |
would all columns in the a bodys interchange what years manul steering /auto trans thank you |
| Author: | Doctor Dodge [ Sun Apr 04, 2004 11:19 am ] |
There are a lot of different steering column types for the A-Body cars so the quick answer to your question is no. Many of the columns do inerchange, the main groupings are: 60-61 62-66 67-71? (ignition key moved into column) 73 & up (locking column and all kinds of wiring differences) Steering shafts inside the column has more interchangeability, basically it is shorter for the power steering box. What year / model is your car and what are you trying to do? DD |
| Author: | Guest [ Sun Apr 04, 2004 11:50 am ] |
| Post subject: | coulum |
a friend has a 69 dart with a bad coulum there is a 71 parts car he can get its a 100miles away a tree fell on it crushed the rear end anyway he wanted to know thanks for the info i will pass it on |
