It is currently Fri Jan 31, 2025 2:56 am
 Post subject: slant 6 burnout
PostPosted: Mon Apr 05, 2004 5:51 pm
I have an 84 d100 slant/4spd, and am wondering if anybody can do a burnout with a stock 1 barrel. This truck has a disadvantage w/230000 miles, and think that something is wrong, and think this might be a good way to find out if something is wrong.
PostPosted: Mon Apr 05, 2004 5:57 pm
Chances are if you attempt a burnout something will go wrong if nothing has already. That's very hard on your powertrain. A simple road test will tell you everything you need to know about how it drives.
PostPosted: Mon Apr 05, 2004 6:05 pm
I've done many a burnout in the '71 1bbl. Of course the tires are crap.
1971 Valiant, Bone stock
1993 Saturn SW2, Not very stock.
PostPosted: Mon Apr 05, 2004 7:04 pm
If you can't do a burnout with a 4 speed something is REALLY wrong. :shock:
PostPosted: Tue Apr 06, 2004 8:56 am
Then there is definately something wrong with my 225 - 4 speed as well,... and I got a 2 barrel! :cry:
OK, i CAN do a burnout, but it feels like instantly killing the car :?
But that's why I'm working on another 225 engine right now. Figured it would be easier to buy an extra block instead of pulling the one that's in there now. :lol:
1965 Barreiros Dodge Dart. 225 / 4 speed.
PostPosted: Tue Apr 06, 2004 8:13 pm
Alright, if you feel you MUST spin your tires to ensure your car has normal torque, may I suggest running the front end up to a concrete barrier or something solid so youre at least not stripping the brakes out of the truck while you do this?
I still think pulling out to pass and romping on the gas is just as effective an indicator of engine power and doesnt involve roasting tires and brake linings. But if that's what you really want to do, at least soak down the tires with WD40 or Javex. The tires will break loose a lot easier and the Javex will create plenty of dramatic stinky smoke to enhance the effect. Some stunt cars actually have bottles filled with this stuff in the trunk with washer motors and nozzles aimed at the tires so the tires will break loose at the touch of a button. The now-defunct Insta-Skid corporation prepackaged kits like this for second unit companies like William F. White a few years ago. It would be easy enough to build.
PostPosted: Wed Apr 07, 2004 9:26 am
had a friend who had a volare w 1 bbl slant and 4 spd. overdrive.There was absolutely nothing wrong with this car,ran excellent.Could NOT lay as much as a patch of rubber !!! Believe me,we tried !!!!
PostPosted: Wed Apr 07, 2004 10:45 am
tire smoking is fun and might do a little myself but there are more effective ways to check your engine for problems my grandfather has a 84 ram with a super six that wont smoke the tires auto though but it spinns well in gravel and sand but he hauls hay with it so it's just geared wrong for tire smoking got a 75 cornet that wouldn't burn ruber either 400 big block in it so some car do and some don't so don't put to much faith in that as a test
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Wed Apr 07, 2004 11:38 am
whether or not you can spin the tires depends on a lot of things...
road surface
tire quality
engine torque
clutch quality
rear end gearing
I wouldn't use that as an indicator... Even though I've got a 4spd and 3.55 gears in my D-100 it won't spin the tires. Of course that could be the crappy clutch and good tires.
Seriously, If you have 2.94 gears & good tires on the truck, for example, you're not likely to spin the tires.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
 Post subject: Burning rubber.
PostPosted: Wed Apr 07, 2004 11:50 am
:lol: You would have to raise the pressure in your tires before you try to lay some rubber, even check your rear suspension, to much jumping is bad for your rearaxel.
Lasse
Lasse
Signet -66 225
Holley 600 Offy-5270 Dutra Dual,regrind. cam 272 0,420 110, head shaved 0.100 slight.ported
MSD6A
A904
7 1/4 3.23
PostPosted: Wed Apr 07, 2004 12:25 pm
Last year we took the GodsRods Duster to one of our local Mopar Club car shows... I entered the burnout contest... tried repeatedly to spin the tires in a puddle of water to no avail... I drove away in shame and embarassment.
It was in its original high mileage, pulled out of a field and tuned up state with big tires and 2.76 gears.
I was really looking forward to going back this year with the new pumped up engine with four barrel and headers, new transmission, 3.91 gears and a set of really skinny, really high pressure, soaked for a week tires.
They're not doing a burnout contest this year! Oh well.
PostPosted: Wed Apr 07, 2004 1:17 pm
The only way I could manage spinning the tires in my 71 duster (225, 904, 2.76 rear) is on dry asphalt is by doing neutral drops.
PostPosted: Wed Apr 07, 2004 10:41 pm
8.4:1 motor with 15k miles on it, stock head, 2 bbl cast iron manifold, 2 bbl 500 holley, 3.23 peg leg. Of course this was an old setup but it shows the slant do have some power.
Pete
PostPosted: Thu Apr 08, 2004 1:18 am
nice pic. my video i made of my stock slant doing a burnout didnt turn out quite that good. i made the video as a visual aid while doing a persuasive speech over why the dodge dart should be considered the greatest car ever built.
PostPosted: Thu Apr 08, 2004 11:16 pm
my slant has dual webers, dutra duals, stock auto, and stock 2.76 rear end. NO WAY CAN I LAY RUBBER, my brakes suck already
caesar
Users browsing this forum: Google [Bot] and 9 guests
