| Fuel tank 1967 vers 1971? https://slantsix.org/forum/viewtopic.php?t=8961 |
| Author: | skraecken [ Wed Apr 07, 2004 11:40 am ] |
| Post subject: | Fuel tank 1967 vers 1971? |
Hello from Sweden! Does anybody know if a fueltank from a 1971 Valiant fits on a 1967 model? Regards Lasse |
| Author: | Doc [ Wed Apr 07, 2004 7:14 pm ] |
Filler neck size and the shape should be the same, there may be some extra vapor return fittings on the 71 tank. |
| Author: | skraecken [ Wed Apr 07, 2004 10:52 pm ] |
OK Tnx! Lasse |
| Author: | junkyardhero [ Fri Apr 09, 2004 9:40 am ] |
skraecken, if you're talking about an A-body then proceede with caution. i know that 67 barracudas attached the tank with a single strap, while 68 and 69 got two straps across a tank that was shaped a little differently. I don't know if MaMopar carried the single strap across the line for the A's in 67, but i can tell you with a level of confidence that the dual strap design was carried from 68 till the bitter end on all of the a-bodies. better to check before dropping the coin IMHO... -JYH 64 Dart, tank? what tank? *evil laughter* |
