It is currently Thu Jun 18, 2026 4:29 pm
PostPosted: Thu Mar 03, 2005 3:24 am
Ok first off I know this is a slant 6 site. I dont know were to find the answer to this though.
Could I replace the 1.5 rockers on a 74 stock 318 and replace them with 1.6 or even 1.7 rockers with out replacing the valve springs and with out causing valve to piston clearance problems???
PostPosted: Fri Mar 04, 2005 9:37 pm
On the 1.6 I think stock springs will work,it depends on your cam, for more info on this check moparchat.com,register and go to performance talk ask there and you will get your answer,,speedfreak.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 3 guests
