| Is weld Thru Primer Really Weld thru?? https://slantsix.org/forum/viewtopic.php?t=9075 |
| Author: | relic-lover [ Sun Apr 18, 2004 8:40 pm ] |
| Post subject: | Is weld Thru Primer Really Weld thru?? |
I am having difficulty in making clean welds after applying weld through primer on the work pieces. I got a good name brand weld thru primer because I suspected one might have trouble with a cheepo brand. Does this always happen when using primer with a MIG welder? Any way I am about to sand (or sandblast) off the primer where I need to make the welds - Any other easier ideas? Thanks - |
| Author: | steponmebbbboom [ Mon Apr 19, 2004 3:26 am ] |
I believe weld thru primer is only intended to be used with a spot welder. |
