| Four pin ballast resistor https://slantsix.org/forum/viewtopic.php?t=9078 |
| Author: | busboy [ Mon Apr 19, 2004 6:23 am ] |
| Post subject: | Four pin ballast resistor |
Can I use a four pin ballast resistor in my two pin car? It was suggested that I could use two of the pins at a time, then if they failed switch the terminals to the other two to get me home. Does this sound right? Need electrical help! Thanks. |
| Author: | RG [ Mon Apr 19, 2004 8:09 am ] |
It will work. However, not sure if the voltage difference is something that will give problems down the road. |
| Author: | SlantSixDan [ Mon Apr 19, 2004 12:08 pm ] |
No, this will NOT work properly. The two resistors in the four-pin unit are of very different resistance. Just carry a spare 2-pin unit in the glovebox or, if you want, bolt the spare to the firewall. |
