| Early 8 1/4 ring gear https://slantsix.org/forum/viewtopic.php?t=9084 |
| Author: | GUEST [ Mon Apr 19, 2004 9:28 am ] |
| Post subject: | Early 8 1/4 ring gear |
I found a 65 Belvedere (slant w/3speed) in a yard this w/e. It had what appeared to be an 8 3/4 in it, but when I checked the gear it was a 741 case w/3.31 ratio. Will this bolt into my A-body housing? I had never heard of this unit. |
| Author: | sixinthehead [ Mon Apr 19, 2004 9:50 am ] |
741 has a smaller (read weaker) pinion than the 489, but should work fine for you; still plenty strong for an A-body slant. |
