| early Valiants and Lancers: does the shift linkage match up? https://slantsix.org/forum/viewtopic.php?t=9110 |
| Author: | crosleykook [ Wed Apr 21, 2004 12:24 pm ] |
| Post subject: | early Valiants and Lancers: does the shift linkage match up? |
How different is the floor shift linkage/shift lever set up of a '61 Lancer and the set up in the early Valiants? The transmissions are the same, but would the Lancer set-up fit properly in a Valiant? tim |
| Author: | relic-lover [ Wed Apr 21, 2004 9:30 pm ] |
| Post subject: | For 3 speed manual |
The 61 Lancer with the 170 engine and the 61 Valiant (only offered with 170) show all the same parts in my books in the shift linkage for the 3 speed manual. The 61 Lancer with the 225 has one different part - the 1st and reverse shift rod. |
| Author: | sixinthehead [ Thu Apr 22, 2004 8:12 am ] |
How about 62? Any changes? |
| Author: | crosleykook [ Thu Apr 22, 2004 11:58 am ] |
I don't think the floor shifter was available on the '62 valiant (which is why i had to cut a hole in the floor of mine. |
| Author: | 72Duster [ Sun Apr 25, 2004 11:55 am ] |
@ crosleyhook: Did you swap in a 4 speed ? I have a 62 Lancer 3onthetree and I can get a 4sp OD that I´d like to swap sometime, but found about zero information an floor humps, linkage and stuff... Any information appreciated! Thanks, Chris |
| Author: | Doctor Dodge [ Tue Apr 27, 2004 11:03 pm ] |
This is a "doable" and worth-while swap. You will have to cut a large hole in the floor. You will have to use the OD 4-speed bellhousing and make a special pivot bracket to keep the clutch "bellcrank" in the correct position. You will need a special speedo cable assembly (1966 A-body) You will need a slip-in type driveshaft that will most likely need to be shortened. DD |
| Author: | 72Duster [ Thu May 06, 2004 2:48 pm ] |
Thanks Doc! Great site, great people. Without you, I´d be lost ... Thanks! Christian |
