| 1bbl v. 2bbl at the strip https://slantsix.org/forum/viewtopic.php?t=9250 |
| Author: | 64 Convert [ Thu May 06, 2004 11:36 am ] |
| Post subject: | 1bbl v. 2bbl at the strip |
My experience with both setups on similar vehicles convinces me there is a definite seat-of-the-pants difference between a one barrel and a Super Six on the street. My visits to the track suggest that the time slip difference is in the half-second range for the quarter-mile. Has anyone done serious track comparisons between the two intake combinations on the same car? |
| Author: | Guest [ Thu May 06, 2004 12:14 pm ] |
With a stock engine with headers i picked up about 6/10 of second with the supersix setup. |
| Author: | slantzilla [ Sun May 09, 2004 4:30 pm ] |
If the 1bbl you replace is working properly you will gain about 10 horse with a Super Six. It's still a pretty small carb. |
| Author: | dsteamboat [ Thu May 13, 2004 5:57 pm ] |
How much of a difference would there be between a Super Six (BBD) set up with dual Clifford headers and an Offy with a Holley 390 CFM 4 bbl + dual Clifford headers? I plan on having the engine rebuilt and was wondering if it is worth it to convert to the Offy + 4 bbl. Thanks. |
| Author: | slantzilla [ Thu May 13, 2004 7:31 pm ] |
When I went from a SS to a 390 and Offy on my Duster I gained about .6 and 4 mph. |
| Author: | dsteamboat [ Thu May 13, 2004 7:51 pm ] |
Thanks. That is not much of a gain. I think I will stick to my Super Six. |
| Author: | slantzilla [ Fri May 14, 2004 7:56 pm ] |
Quote: That is not much of a gain.
Uhhhh, that's a considerable gain actually. I'd guess in the neighborhood of 25 horse at least. |
| Author: | GunPilot [ Sun May 16, 2004 11:12 pm ] |
I'd slap my granmaw for six tenths. |
| Author: | Guest [ Mon May 17, 2004 12:13 pm ] |
GunPilot, I must be more desperate than you, I'd vote for John Kerry if it got me 6/10 ET. Cecil |
| Author: | slantzilla [ Mon May 17, 2004 1:29 pm ] |
Quote: GunPilot, I must be more desperate than you, I'd vote for John Kerry if it got me 6/10 ET.
Not me, I'd just dial down. Cecil |
| Author: | 225dart [ Sat Jun 05, 2004 4:08 pm ] |
i gained .44 from a properly tuned 1bbl to 2bbl setup on my 74 swingerwith 2.76 gears. but i also switched to a jr header at the same time so im sure that helped some. but, i still kept the 1 7/8" headpipe to the muffler so i could keep the test as fair as possible. you can see some of my results in the virtual dragstrip forum. wow, another .6 going from a ss to a 390 holley? hmmm, will it still fit under the hood with a stock type aircleaner? i like my almost bonestock looking setup. --chad |
| Author: | Ron Parker [ Sun Jun 06, 2004 4:16 pm ] |
If it is a street car you can pick up about .5 in the 1/4. Its all about how much is it going to cost and the effort. Hell I would vote for Bagel for President than John Kerry Hell Hath No Wrath Than A Possum Scorned |
| Author: | slantzilla [ Sun Jun 06, 2004 8:13 pm ] |
Quote: Hell I would vote for Bagel for President than John Kerry
If nominated I will not run, if elected I will not serve. |
