| 10" drum brake conversion https://slantsix.org/forum/viewtopic.php?t=9337 |
| Author: | Flyntgr [ Mon May 17, 2004 10:57 am ] |
| Post subject: | 10" drum brake conversion |
on an A body seems to require only: drum, spindle and backing plate exchange according to my limited knowledge and a search of the messages of this Forum. Is that correct for my '62 Valiant, using '73 ten inch drums, etc, from a Dart or Duster? I want to keep the SBP because I have new Crager SS's in the SBP. Thanks everyone! |
| Author: | Guest [ Mon May 17, 2004 12:04 pm ] |
In '73, the upper ball joint size changed. You'll need the '73 upper control arm for the new joint size. Cecil |
| Author: | oibrownskin [ Tue Jun 15, 2004 5:28 pm ] |
what is SBP? |
| Author: | 73dart_swinger [ Tue Jun 15, 2004 6:48 pm ] |
Small Bolt Pattern, 5 on 4in Large Bolt Pattern, 5 on 4.5in |
