It is currently Fri Nov 27, 2026 12:20 pm
PostPosted: Wed Jun 02, 2004 9:18 am
Contributor
I'm converting my '64 Valiant to a Super Six setup and would like to know what others have done with '63-'66 SS conversions.
I have a suspended accelerator pedal from my donor Aspen, but the trim pattern on the pedal doesn't match the clutch and I'd like to make it look as original as possible. Did you use the '64-'66 V8 pedal, or have you found a suspended pedal with the older trim pattern?
PostPosted: Wed Jun 02, 2004 4:24 pm
I used the pedal from a '75 Dart. A simple, one piece bracket, with integrated cable. Not the two piece setup from the F-bodies.
PostPosted: Wed Jun 02, 2004 5:40 pm
Contributor
Hmmm, the '79 Aspen pedal I have is a one piece design. The one I put on my '73 truck was a two piece suspended pedal from a '91 truck.
