It is currently Mon Jun 22, 2026 8:20 pm
 Post subject: Factory Specifications
PostPosted: Sun Jun 06, 2004 1:51 pm
Where do I find the block dimensions for bore spacing and head bolt location? I also need the specs for the bottom end.
PostPosted: Sun Jun 06, 2004 3:24 pm
The bore centers are at 4 inch "center to center".
There is not published information on these specs, I would measure a block for the bolt patterns.
Soooo.....thinking about making a billet block??? :shock: :wink:
PostPosted: Wed Jun 09, 2004 2:42 pm
I thought the bore centers were 4" between the center two, and less (3.92"??) between all of the others. Or, it could be the other way around (less between center two). I know I have read something like this...
 Post subject: Bore Centers??
PostPosted: Thu Jun 10, 2004 4:52 pm
You have a pretty good memory Lou? You are correct. I pulled the old Slant 6 News #49, and in the "History of the Slant 6" it says the following:
"The engine had the cylinders arranged in three pairs. The distance between 1&2, 3&4, 5&6 was 3.98". The distance between 2&3, and 4&5 was 4.00". The main journals were under the spaces between cylinders 2&3 and 4&5. The extra.020"(the difference between the 4.00" spacing and the 3.98") was needed for the length of the main bearings being used."
By: Willem Weertman
Hope that helps you out.
Rick
