| how much nitrous? https://slantsix.org/forum/viewtopic.php?t=9544 |
| Author: | nitrous/6 [ Fri Jun 11, 2004 3:18 pm ] |
| Post subject: | how much nitrous? |
I am going to be building a motor using 198 rods and 2.2 turbo pistons. How much nitrous will these be able to take before failing? |
| Author: | Doctor Dodge [ Sat Jun 12, 2004 7:22 am ] |
Which 2.2 piston are you planning to use? (these come in cast, hypereutectic and forged) The most common are the cast hypereutectnic pistions from Silvolite / KB. These will take a 100 HP shot and even more if you use the Silvolite pistons with the lower ring lands. If you use a hypereutectic piston, use large ring gaps. Butting rings are a problem with these. DD |
| Author: | nitrous/6 [ Sat Jun 12, 2004 12:33 pm ] |
If I were to get a custom piston instead, when would the 198 rod fail? |
