It is currently Sun Jun 21, 2026 11:52 pm
 Post subject: how much nitrous?
PostPosted: Fri Jun 11, 2004 3:18 pm
I am going to be building a motor using 198 rods and 2.2 turbo pistons. How much nitrous will these be able to take before failing?
PostPosted: Sat Jun 12, 2004 7:22 am
Which 2.2 piston are you planning to use? (these come in cast, hypereutectic and forged)
The most common are the cast hypereutectnic pistions from Silvolite / KB.
These will take a 100 HP shot and even more if you use the Silvolite pistons with the lower ring lands.
If you use a hypereutectic piston, use large ring gaps. Butting rings are a problem with these.
PostPosted: Sat Jun 12, 2004 12:33 pm
If I were to get a custom piston instead, when would the 198 rod fail?
