| Where Do You Mount Your Control Module?? https://slantsix.org/forum/viewtopic.php?t=9588 |
| Author: | Mooosman [ Wed Jun 16, 2004 10:51 am ] |
| Post subject: | Where Do You Mount Your Control Module?? |
Okay, I'm going to do the electronic ignition conversion on my 61 Valiant, and I can't decide where to mount the box itself. I've got the MP wiring harness, and they don't give you very much wire. Where did you mount yours? Nick, Hates points! |
| Author: | Slant6RamTruck [ Wed Jun 16, 2004 12:38 pm ] |
| Post subject: | Anyplace you like |
Different cars had many locations. Look for a spot on the firewall with the correct bolt spread stamped, but I don't know if they had it on cars that age yet. The simple answer is anyplace dry that the wires will reach. Just be sure the box is well grounded. I personally ran a wire directly to the negative battery terminal, but you can just clean the back of the box and sand the paint off the spot you finally pick. Good Luck. |
| Author: | relic-lover [ Wed Jun 16, 2004 1:38 pm ] |
| Post subject: | Control Box location |
My daughter's 61 has it mounted on the right fender on the shelf like area just to the rear of the shock absorber. I think hers is a factory unit taken from a later car and so is not using the MP harness. But that location is in fairly close proximity to the distributor. |
