| Carb Adjustments https://slantsix.org/forum/viewtopic.php?t=9589 |
| Author: | slant addict [ Wed Jun 16, 2004 11:17 am ] |
| Post subject: | Carb Adjustments |
does turning the idle adjustment screws in lean out or richen the mixture? |
| Author: | junkcarwilly [ Wed Jun 16, 2004 11:48 am ] |
In cuts down the flow-leaner. |
| Author: | Doctor Dodge [ Wed Jun 16, 2004 9:56 pm ] |
Clockwise (in) for leaner. Set you idle to 600 rpm then back-out the idle mixture scew (counter-clockwise) to see if the idle speeds-up / smooths-out. If the idle does not change, slowly turn the screw in (clockwise) until you hear the idle speed drop, find that point then back-off 1/2 to 1 full turn. DD |
