It is currently Sat Jun 06, 2026 9:17 pm
PostPosted: Sat Jun 12, 2004 8:33 pm
Hey guys
After my exhaust swap, I smell fuel after a while of OT (not WOT) let's say when hitting hard on the gas at 50 and speeding up to 75 - 80 (I'm not flooring it, not even near) But I don't know if I should blame that on my new ex 'cuz I did some tune up along with the ex replacement. I changed spark plugs, I cleaned the carb (ain't leaking) and I installed a new distributor. :?
I'll appreciate any comment on this matter.
Juan.
PostPosted: Mon Jun 14, 2004 11:31 am
You smell fuel with the engine running and the car moving down the road? :?
What carb are you working with?
Are there any exhaust system leaks/
How does the tailpipe exit the rear of the car, straight back or off to the side?
PostPosted: Mon Jun 14, 2004 12:42 pm
Hey Doc
No ex leaks, and the pipes are straight back (one on each side)
I'm working with a single barrel holley, but not the 1920. It's similar, with bigger venturi, bigger throat, more CFM and more bowl capacity. It says holley 1922, but I think that's a local version of the 1920.
Today I lowered the bowl level (regulated the float) and seems to be better... maybe it was just too "fat" ? :?
PostPosted: Mon Jun 14, 2004 11:27 pm
Could be your float bowl vent isn't closing when you open the throttle. Its only supposed to be open at idle and when the engine is shut off.
PostPosted: Wed Jun 16, 2004 8:07 pm
where's that vent? the dumba*s question of the year, I suppose, but I don't know where it is
 Post subject: You ve got mail
PostPosted: Thu Jun 17, 2004 9:48 am
I emailed a pic for his enlightenment. :shock: Hope it's not too blurry.
PostPosted: Thu Jun 17, 2004 10:49 am
Thanks, I didn't get it yet... but I'm sure I'll get the light 8)
 Post subject: Link
PostPosted: Thu Jun 17, 2004 1:51 pm
http://www.potentialtech.com/pmoran/vent.jpg
:wink:
I don't know why, but my email doesn't seem to work half the time. I didn't even get a bounce notice?
That why I'm posting as a guest. :roll:
PostPosted: Thu Jun 17, 2004 2:36 pm
Thanks! but mine hasn't that vent. It's a holley licensed carb manufactured in Argentina, then modifyed to get 300 CFM plus outta it. It's a manufacturer's modification, not custom. Maybe I can post some pix... That explains why I made a fool outta myself with the question. :oops:
PostPosted: Sat Jun 19, 2004 2:24 pm
my float cover was leaking allittle, causing a fuel smell
Users browsing this forum: Ahrefs [Bot] and 6 guests
