| Disc Brake/Proportioning valve Q's https://slantsix.org/forum/viewtopic.php?t=9603 |
| Author: | Old Car Scott [ Fri Jun 18, 2004 2:25 am ] |
| Post subject: | Disc Brake/Proportioning valve Q's |
Let me hope I'm not too confusing.... If I had a power disc brake set-up on a car, could I remove the power brake master cylinder and booster and swap on a manual brake master cylinder and not experience any problems? Are the proportioning valves different between manual disc and power disc brakes? Anyone? |
| Author: | Matt Cramer [ Fri Jun 18, 2004 7:17 pm ] |
Not only are the proportioning valves the same, I think some years the master cylinders are the same too. The lines may be a little different though. |
