It is currently Sat Nov 28, 2026 4:19 am
PostPosted: Thu Jun 24, 2004 1:34 pm
I recently got all of the Dart's gauges working again, the only problem is that the previous owner clipped the wire that ran to the Temp gauge and then installed a cheap aftermarket gauge under the dash. So, I went and bought what I believe to be the correct sending unit from the parts store and hooked it to the original wire with a ring connector. Now it just pegs out when attatched. I'm assuming that it's because I used a ring connector and nut instead of the original style "boot". If this is the case, where on earth can I find the proper connector?
thanks,
josh
64 Dart 170 /6
PostPosted: Thu Jun 24, 2004 2:13 pm
It shouldn't matter how you connected the wires together. Does your fuel gauge work correctly? If not, then the voltage limiter is bad. This will need to be replaced. The voltage limiter should be located on the dash circuit board next to the fuel gauge.
PostPosted: Thu Jun 24, 2004 2:52 pm
All the other gauges are working fine. I wired in the voltage limiter and hooked everything up, and the fuel gauge works flawlessly. My problem is just the temp gauge. as soon as I touch the wire to it, the gauge pegs out to hot.
-josh
64 Dart 170 /6
 Post subject: Temp sending unit gauge
PostPosted: Thu Jun 24, 2004 8:08 pm
Either the new sending unit is shorted or your "old" wire is grounded some where along its length.
Rafa
Hecho en México
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
