It is currently Sat Oct 10, 2026 3:50 am
PostPosted: Fri Jun 25, 2004 8:15 am
I know you guys know what adapter I would need to mount this carb to my super six intake.
My brother in law just gave me this thing last night, he took it off of a 79{I think} 400cid V8. it has
R 6886 1A
3751486
1307
stamped on it
this thing should flow 350cfm?
Do you think It will kill my milage if I drive no harder than I do now?
PostPosted: Fri Jun 25, 2004 2:03 pm
There aren't any factory adapters. A homemade one can be made, but it will have to be offset a little. This is because the bolt pattern is so close in size to the small BBD, the bolt holes overlap. The carb will have to be offset so you can get to the bolts that will hold the adapter to the manifold.
Cecil
PostPosted: Sat Jun 26, 2004 5:29 am
I doubt I'll be able to use this carb. I guess I'll just drill out some jets for my BBD.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 27 guests
