It is currently Sat Oct 10, 2026 7:37 pm
 Post subject: Air Cleaner
PostPosted: Tue Jun 22, 2004 3:00 pm
im thinking about putting an open element air filter on my car. what will i do about the breather that has the hose attached to the side of the air cleaner? im also thinking about running a hose off my intake snorkel to form a sort of cold air intake. which one would give me more of a boost? i figure i wont be able to tell the difference but itll be there, so any body have an opinion?
PostPosted: Tue Jun 22, 2004 5:07 pm
If you go with an open element air cleaner, just get a push in breather cap without the nipple that will fit the grommet on the valve cover. Late '70's cars with slants will have the closed air cleaners with a hose that goes to the inner fender for cool air.
PostPosted: Tue Jun 22, 2004 5:16 pm
anyone know where i can get a base plate for an open element that will fit the carter bbd 2 bbl. i saw a pic on here sometime and someone had an open element and the top had a super six sticker on it. looked pretty cool so i thought id do someting like that unless i might get a little better performance with the "cold air intake" idea.
PostPosted: Tue Jun 22, 2004 8:11 pm
you may be talking about mine
It is actually a super six aircleaner that I cut down with a dremmel and used brake fluid to remove the paint and not the sticker.
PostPosted: Wed Jun 23, 2004 11:32 am
i read on slantsix.com of a guy who dynoed his car with the stock air cleaner and then put an open element on and gained 5 horses and 17 ft/lbs of torque. so what do you guys think, cold/ram air type setup or open element air cleaner for a little more power? would the increased flow of an open element out weigh the gains of a cooler air charge?
PostPosted: Wed Jun 23, 2004 12:18 pm
For reference:
Air cleaner is "super six" type with 4bbl "bell" grafted into base and additional snorkel added. Please note that I still run the thermostatically controlled carb heat (from a "stove" fashioned on the headers) and vacuum controlled air doors on both snorkels to close out cold air until warm-up...
D/W
If it ain't broke, fix it!
PostPosted: Wed Jun 23, 2004 12:26 pm
Neat idea... and simple. I'm filing this one away for future reference. :)
D/W
 Post subject: New air cleaner
PostPosted: Wed Jun 23, 2004 4:40 pm
Mr Gasket makes a 10" diameter 2bbl chrome air cleaner. They have it listed an PN 9798.
The cut-down super six air cleaner would be cheaper and would probably work better as the OEM air filter seems to be a lot bigger.
PostPosted: Thu Jun 24, 2004 7:55 pm
Try flipping the air cleaner lid upside down. I did this on my car and noticed quite a change even with the stock 1-barrel. You can also get a punch out and cut several round holes in the side of the air cleaner. Will look really cool too.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue Jun 29, 2004 11:02 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
You can get a plastic adapter for the Mr. Gasket air cleaner at Pep Boys (and probably other places, too). I was able to get a skinny K&N airfilter that looks pretty cool, too.
The plastic adapter comes with a nipple that you can drill out and attach an oil breather tube to, but I prefer that breather w/o the hose.
Best of luck,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Tue Jun 29, 2004 12:17 pm
73Dart_Swinger
Here is link to the air cleaner I had installed when I was running the SS setup.
http://www.slantsix.com/UBB/Forum17/HTML/000072.html
PostPosted: Tue Jun 29, 2004 8:51 pm
Do they make an adapter to mate a 1-barrel to 5 1/8 neck air cleaner. I think a 10 inch open element air cleaner would look really cool on my car.
Hey 66 Dart, I love your air cleaner setup, how does it sound? Does it moan when you get down on it. I have a 14 inch open element on my truck and it makes a really loud howling sound at full throttle. Intimidates the heck out of a guy at a red light.
82 D150-225/727
PostPosted: Tue Jun 29, 2004 11:12 pm
...Shepherd to Lost Sheep, Shepherd to Lost Sheep, this 'sheres Uncle Jesse, ya'll boys in there? ;)
kyut kyut kyut,
D/W
Users browsing this forum: Amazon [Bot], Bing [Bot] and 26 guests
