| Gas in oil https://slantsix.org/forum/viewtopic.php?t=9715 |
| Author: | Jeb [ Wed Jun 30, 2004 5:17 pm ] |
| Post subject: | Gas in oil |
After my Duster flooded real bad the other day, I noticed that my oil has a really strong, gassy, smell. Is there gas in my oil? I have never seen this before. |
| Author: | callpaladin [ Wed Jun 30, 2004 5:29 pm ] |
| Post subject: | gas in the oil |
hello jeb- have seen this before in sl6s and 318s but it is uncommon. a damaged cracked or loose body carb could cause this, but themore likely cause is a leak in the diaphram of the fuel pump. when the arm flexes for a pump shot on the cam eccentric, gas can dump into the oil pan. how old is the fuel pump? |
| Author: | Dennis Weaver [ Wed Jun 30, 2004 5:30 pm ] |
Change your oil right away, dude - and hope that's all it was. Keep an eye on things to make sure your fuel pump's not leaking gas into the crankcase. If it is, replace the pump. D/W |
| Author: | Jeb [ Wed Jun 30, 2004 7:42 pm ] |
I have heard that when it gets hot, the gas will evaporate out. I know it is not the fuel pump because it was replaced last month and the carb is brand new. |
| Author: | moparfreak [ Wed Jun 30, 2004 9:42 pm ] |
bad rings maybe or possibly the head gasket but definatly change the oil or you could blow your self up |
| Author: | MitchB [ Wed Jun 30, 2004 10:07 pm ] |
| Post subject: | Re: Gas in oil |
Quote: After my Duster flooded real bad the other day, I noticed that my oil has a really strong, gassy, smell. Is there gas in my oil? I have never seen this before.
Normal if you flooded bad. Change your oil right now. Mitch |
| Author: | Slant6RamTruck [ Thu Jul 01, 2004 12:05 pm ] |
| Post subject: | Never hurts to have fresh oil |
Better safe than sorry, change the oil, but I wouldn't lie awake at night over it. A few good wiffs of gasoline or some on your hands/shoes/clothes, and EVERYTHING will smell like gas for hours. A few more wiffs and you'll see pretty colors OOooops, those are ambulance lights Sometimes "new" pumps are junk from the factory, just keep an eye on it in case. |
| Author: | Jeb [ Thu Jul 01, 2004 6:07 pm ] |
I changed the oil this afternoon. Will let you know if anything develops. |
| Author: | mszauner [ Fri Jul 02, 2004 6:32 am ] |
| Post subject: | Fuel Pump |
I had that happen with 3 different new fuel pumps. I never could figure out why the diaphrams kept rupturing. I eventually installed a Holley electric fuel pump and have been having no problems since. Mike |
