It is currently Sat Jun 06, 2026 8:35 am
 Post subject: hydraulic head swap
PostPosted: Fri Jul 02, 2004 11:02 am
Car Model: 1964 Valiant
My '83 hydraulic lifter moter has a leaking head gasket (bubbles in coolant, missing badly), but not yet using water, no water in oil.
I have two good heads to use for a swap.
newly rebuilt '64 head
'78 cast crank motor
Would either of these heads accept the hydraulic valve gear(including cam/lifters)?
Or would I have to also swap to the solid lifter camshaft? Any other issues to consider? Valve cover etc.
PostPosted: Sun Jul 04, 2004 7:46 pm
It doesn't sound like either of those heads would work unless you change to a solid camshaft & lifters. I prefer solid lifters myself. Hydraulics to float at about 4500-5000 RPM.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Jul 05, 2004 8:00 pm
I believe either head will work with the hydraulic stuff installed.
With the 1978 head you will not be able to remove/change lifters with the head installed. I think the main difference between the solid lifter head and the hydraulic lifter head is that it was modified to allow removal of the lifters without removing the head.
IN 1978 Chrysler installed hydraulic cam, lifters, and valve train in 20,000 high end Volaré/Aspen cars with Air Conditioning to test the durability of this then new setup. The hydraulic valve train entered production in 1981.
