It is currently Sat Nov 21, 2026 10:49 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: 170 long rod
PostPosted: Fri Jul 09, 2004 10:23 pm
I'm in the process of building a high-reving and hopefully high horsepower naturally aspirated 170.
I picked up some slightly used 6.125" sbc Carrillo rods off of e-bay for $80. I think that's a bargain considering they cost over $1,000 new. They weigh about 130 grams less than stock 170 rods. I plan on running some 89mm pistons with a 1.375" comp. ht.. So with the lighter pistons and rods, that should make for quite a weight savings in the reciprocating assembly.
Now I figure a 170 crank is already stronger than a 225 crank because of its shorter throws. My concern is, how much will it weaken the crank to turn the rod journals down to sbc size? I realize the big end width is narrower on the rods but my machine shop says I can have the crank journals welded.
Any opinions on this?
Franklin
'61 Valiant
PostPosted: Sat Jul 10, 2004 5:45 am
Is there a particular reason, you want to spend that kind of time and money on a 170? The same amout of money spent on a 225, will result in at least 50 more HP, then a 170.
PS. I run 170 engines, but that is what I had, from when I ran in stock eliminator. Plus I like to be different, but I am going to do a 225, since I got one for free.
PostPosted: Sat Jul 10, 2004 6:38 am
1. agree with above, 170 is a waste of time.
2. welding and re-grinding the crank may cost $6-700.
3. 1.375" CD will give you about 4-1 compression. You need 1.9925" CD for zero deck.
What us it that you think this will accomplish?
PostPosted: Sat Jul 10, 2004 9:41 am
Panic, a 1.99" CD would put the piston about 5/8" out of the hole.
Agreed on not cost effective way to make HP, giving up 55 inches for a lighter reciprocating and higher reving motor will be hard to make up.
Cecil
PostPosted: Sat Jul 10, 2004 10:28 am
Interesting setup, the 89mm pistons might be pushing it also. That would be close 3.5" and cylinder wall thickness may become an issue. Do you plan on a big valve head also?
A chrylser engineer has said, if you can keep the cam lopes oiled, you can run the 170 at 7 grand all day. What chassis are you planning to but this engine into?
PostPosted: Sat Jul 10, 2004 10:40 am
This combo is "do-able" but be sure to do all the math, what compression do you come-out with?
Stock 170 rod is 5.7 so your sbc rod puts you .425 higher up.
SL6 piston has a 1.76 c/h so your new piston brings you back down .375
The way I see it is that the piston will "pop-out" .040 and this will interfer with the edges of the head gasket / combustion chamber unless you do some "trimming".
As for the crank pins, don't waste the $$ on welding them, just grind the 2 inch by .700 wide sbc journal centered on the current 2.187 x 1.200 wide "pin". This looks funky but it works, there is even enough meat to do some off-set grinding and still have walls left for side clearance oil control.
What is the situation with the piston pin? (small end) Import pistons usually have a small piston pin. (sbc is at .937??)
Cam choice will be important, how high do you want to rev this engine?
PostPosted: Sat Jul 10, 2004 12:19 pm
Charlie, I like to be different also :D I don't think it would be any cheaper to build a 225 and I'm not convinced you can't get the same or more horspower from a 170. Besides I like small high reving engines. But I have a 225 I plan on building sometime also.
I may have to shave the pistons a little but I want to run some pretty high compression. With a 1.96 to 1 rod to stroke ratio and a long duration cam I think it will take more compression. The valves I'm running are 1.73" IN. 1.53" EX.
Thanks Doc, for that tip on crank grinding. The pin end on sbc rods is .927 I will need to bush them down to .866 for the pistons. I want to rev this thing to about 8 grand. I already have a custom cam, 254 degrees duration @ .050" lift, .485" lift, 112 degrees lobe sep.
It's going in my '64 Dart but I'm far from getting this thing all together. Maybe by next spring.
Franklin
'61 Valiant
PostPosted: Sat Jul 10, 2004 2:30 pm
Deck: 9.68"
170 stroke: 3.125"
1/2 stroke: 1.5625"
rod: 5.707"
CD for zero deck: 2.4105"
SBC rod: 6.125"
CD for zero deck: 1.9925
1.375" CD piston will be .6175" down from zero deck @ TDC.
Result: no compression.
PostPosted: Sat Jul 10, 2004 4:27 pm
With the 170 being a zero deck motor, you will almost definetly require valve notches. Make sure the piston top has enough meat, for the notches.
PS. where in Florida are you? You can send me a private message, or a personal e-mail, if you wish. Maybe we could get together.
PostPosted: Sat Jul 10, 2004 5:32 pm
Panic, I don't know where you got that deck ht. number but my block is right at 9.06"
1.5625" + 6.125" + 1.375" = 9.0625"
Franklin
'61 Valiant
PostPosted: Sat Jul 10, 2004 8:27 pm
My source?
Chrysler service manual.
Mopar "Engines" book.
Allpar.
"Mopar Action" magazine.
Where did you measure from?
PostPosted: Sun Jul 11, 2004 11:51 am
Panic, That's interesting. Is it possible there was a misprint? As far as I know all slant six engines use the same size stock pistons with a 1.75" comp. ht. As Charrlie said, the 170 is zero deck ht. motor.
Franklin
'61 Valiant
PostPosted: Sun Jul 11, 2004 11:58 am
The Mopar Performance Six Cylinder Engines guide does indeed claim that the 170 does have a 9.68" deck height. However, stock slant six pistons do not have anything close to a 2.4" compression height. The pistons are 3.51" high, and the Factory Service Manuals clearly show the pin is pretty close to the center of the piston. My guess is that the number in the engine manual is simply a misprint.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sun Jul 11, 2004 12:02 pm
I had always though the 225 block was 1" taller than the 170.
This can't be correct as the 170 rod is 1" shorter, along with a 1" shorter stroke, makes the 170 block 1.5" shorter than the 225.
Cecil
PostPosted: Sun Jul 11, 2004 5:54 pm
You guys got me wondering, so I went to the shop and started measuring. The Mopar engine manual, 9th edition is wrong. Just measured one 170 block, crank centerline to deck is 9.065 inches. Measured 3 different pistons for compression distance.
Stock cast: 1.760
TRW forged: 1.754
Jahns cast domed high comp: 1.813 from pin center to flat of piston plus a .300 dome.
Did not measure any 170 rods, as all of mine have pistons on them. FSC, and Mopar engine book, both, list the rod lenght at 5.707
Users browsing this forum: Google [Bot] and 6 guests
