bell housing for 833 OD trans.
https://slantsix.org/forum/viewtopic.php?t=9798
Author:  snorklewurst [ Mon Jul 12, 2004 7:52 pm ]
Post subject:  bell housing for 833 OD trans.
do the bell housings from 8's bolt up to 225 6's?
Author:  volaredon [ Mon Jul 12, 2004 9:26 pm ]
NO!!!
Author:  andyf [ Wed Jul 14, 2004 8:25 pm ]
Only if you use an adapter that converts from /6 to SB pattern. Then you could use a SB scattershield.
Author:  volaredon [ Thu Jul 15, 2004 4:19 pm ]
Do you HAVE an A833OD bellhousing for a V8 that you dont need/cant use?? I NEED IT!
Author:  snorklewurst [ Thu Jul 15, 2004 5:16 pm ]
I believe there is one on ebay right now under mopar bellhousing. I need one for a 225.
Author:  volaredon [ Mon Jul 19, 2004 3:39 pm ]
Check out sl6.com. Someone had one for free today, listed in the parts section. Last couple Ive shipped only cost about $12. it sounds as if he has the clutch, flywheel and all. (may be a little more with all the extras)
