| $100 rear end https://slantsix.org/forum/viewtopic.php?t=9930 |
Page 1 of 2 |
| Author: | heckshemi [ Sun Jul 25, 2004 11:40 pm ] |
| Post subject: | $100 rear end |
Here's my ford explorer 8.8" rear end with 3.73 ratio and posi I got for $89 at the local u-pull-it. I narrowed it 3'' and put on some Mopar spring pearches ($12.99 at Jegs) It's ready to install. Â Â <img src="http://homepage.mac.com/howtoplaydead/.Pictures/mustangmopar_rear.jpg"> |
| Author: | kesteb [ Mon Jul 26, 2004 1:48 pm ] |
Looks good, but didn't the exploders come with rear disk brakes? |
| Author: | heckshemi [ Mon Jul 26, 2004 4:38 pm ] |
'94 and later came with disc brakes, earlier models had 10'' drums. All have 5 on 4 1/2" bolt pattern. |
| Author: | Dart270 [ Fri Jul 30, 2004 8:53 am ] |
What does that sucker weigh? I'd really be interested before you install it... Lou |
| Author: | heckshemi [ Wed Aug 11, 2004 4:30 pm ] |
It weighs about 190 lbs with the drums on a bathroom scale. |
| Author: | Dart270 [ Wed Aug 11, 2004 6:35 pm ] |
Thanks much for the weight - about 10lbs lighter than a comparable 8.75" mopar axle. Lou |
| Author: | heckshemi [ Thu Aug 12, 2004 2:15 pm ] |
Yes, it's a little lighter than a 8 3/4 or 9" and supposedly less parisidic drag yet nearly as strong. I was originally going with an A body 8 3/4" but after getting all the parts together and realizing I'd spent $700 for a housing, sure-grip and decent gears, I sold it. The junk yards are full of explorer 8.8s with posi and 3.55 or 3.73 ratio. If you want 4.10 or 4.56 ring and pinion, they're cheap on e-bay. It's real easy to narrow, you don't have to re-spline any axles. |
| Author: | plymon [ Thu Aug 12, 2004 9:13 pm ] |
| Post subject: | narrowing proceedure |
How is the explorer rear narrowed without resplining axles? |
| Author: | Guest [ Sun Aug 15, 2004 3:44 am ] |
nice question ? how to shorten the rear end ? i,m also in this trouble got a 8" 54 "" and need 52" long . how to shorten a rearend ? btw . i only have acces to euro cars , not easy for me to go to a yunk yard and pick a 8 ore 8,8 axle ! did took me 1 year to get a 8 axle , and it is to wide !!!!!!!!!!!!!!! http://member.chello.nl/h.omvlee |
| Author: | Guest [ Sun Aug 15, 2004 3:55 am ] |
btw :http://members.chello.nl/h.omvlee/ i,m always looking into this site too , nice forum ! good tips and how to . |
| Author: | 72swing [ Sun Sep 12, 2004 3:06 pm ] |
| Post subject: | Narrowed How far? |
Hey, When you say that you narrowed the FMC 8.8 3" do you mean 3" total or 3" on each side? Also, what would prevent you from using a disc brake version of the same rear? Ideas? JRC |
| Author: | heckshemi [ Sun Sep 12, 2004 6:52 pm ] |
The explorer 8.8 is 59 1/2", but the center section is offset about 3" to the right. So I cut 3" off the left tube and used another left axle and now its aprox. 56 1/2" wide. You could use the disc brake model with no problem except adapting the parking brake cable, which looks pretty easy. |
| Author: | heckshemi [ Sun Sep 12, 2004 6:56 pm ] |
That should read, "I used another right side axle". |
| Author: | 72swing [ Sun Sep 12, 2004 7:16 pm ] |
| Post subject: | Offset |
Ah, I am very curious how this entire project turn out. This rear end swap is of particular interest to me since I am also into Fords. I've owned 2 explorerers and modified one fairly extensively, the rear end never broke, even when being used for makeshift rock crawling. Can't say as much about the TTB Front suspension though you should really submit this entire thing to the powers that be here on sl6 and get it made into an article! |
| Author: | GTS225 [ Sun Sep 12, 2004 7:47 pm ] |
Hmmmmmm.....I wonder if a spool is available for the Ford 8.8? I'm giving some thought to a rear-engine , slant-powered dragster, but really don't want to use an 8.25" rear. Roger |
| Page 1 of 2 | All times are UTC-07:00 |
